Old 06-13-2017, 01:44 AM   #122 (permalink)
ar5boosted
ar5boosted's Avatar
Originally Posted by Enki View Post
So you mean you injected water (unmixed) at the same rate as you were consuming fuel right? I ask because I'm pretty sure that putting water in the gas tank is a not so great idea. Lol.
Roughly as much, Yes.
I was using an electric-water-pump and a misting nozzle to spray into the carburetor. There was a switch on the throttle cable to turn the pump on. It idled without the water running.
The water tank was in the back of the van. I wasn't worried about it exploding.
Once I hydrolocked the engine but took off the sparks plug and it started again. Van was stolen otherwise I might have been still driving it.
Originally Posted by teoman View Post
Do you have a thread about it?
Sorry no.
But there is nothing I couldn't do again. I believe that what I did was reproduceable. I still have the pumps and nozzles and the gear.
I think it would work for anyone doing lean-burn and greatly assist.
2003 Renault Scenic - 30% more power with no loss in fuel economy.
1991 Toyota GT4 - more economical before ST215W engine-swap.
previous: Water-Injected Mitsubishi ~33% improved.
future - probably a Prius
The Following User Says Thank You to ar5boosted For This Useful Post:
Enki (06-13-2017)
