Old 06-14-2017, 08:31 PM   #32 (permalink)
Grant-53
You're plenty smart. I'll explain it better. A 600 cc engine turning at 5000 rpm will pump as much air/fuel mixture as a 300cc engine turning at 10,000 rpm. An engine with a compression ratio of 8:1 is less efficient than an engine with a 12:1 compression ratio.
bschloop, Did you build a velomobiles with the thought of selling them? If so check out velosRus.com aka Carolina on recumbents.com as he is making velomobiles uni-bodies.
