Old 06-17-2017, 05:05 AM   #268 (permalink)
cRiPpLe_rOoStEr
Gol tuned for drag-racing
Originally Posted by ChopStix View Post
  • Rear engine car with a couple inch oil pan sump that hangs below the floor board, and how this will work with the above
  • Cooling the engine, and adding back the air ducts lost from the delivery shell addition
  • Venting the rear fender scooping effect without cutting off, or drilling holes in the rear fenders
  • Exhaust tucked under the rear apron getting in the way of the above
On the cooling problem. I've been pondering the concept of ducting air from the rear fenders into the engine compartment. Then discharging it out the back. So the concept of using a diffuser would benefit this effort by providing an air exit point.
But there's SO MUCH under the rear end of these cars I'm not sure there's enough real estate to fit everything.
I've already seen some old air-cooleds converted to water-cooled EA827 engines, with many different fender-mounted scoop arrangements to improve the air flow. Some had small holes or additional grilles around the license plate to get the hot air expelled.
