Old 06-26-2017, 02:57 PM   #94 (permalink)
cRiPpLe_rOoStEr
If a rear-mounted turbo was grafted to a driveshaft with a 2nd one grafted to the other end, the altermotor could go anywhere in between.
It doesn't sound like a bad idea at all, making a twin-stage centrifugal compressor with the alternator placed between the compression stages. Possibly it would not increase too much inertia like the setup driven by a PTO would.
I don't know enough about turbo bearing to know if you could turn one into a PTO [power take off].
Since some earlier jet engines relied on centrifugal compressors which are more similar to the compressor of a turbocharger than the axial ones fitted to modern airliners, and they still have an accessory drive, it doesn't seem impossible to design a turbocharger with a PTO.
