Originally Posted by EcoCivic
Should I unplug the oxygen sensor and see if the mileage improves?
No, that will not help you.
If I understand correctly, the oxygen sensor just trims the air fuel ratio if there is a problem, and it theoretically effects nothing unless it detects that the engine is running rich or lean.
The upstream O2 sensor provides data that helps the map in the ECU regulate fuel/air mix. That would be way important for your current problem. And if there is oxygen infiltration via a crack, it will throw the data off.
This car used to get around 33-36 MPG, but around the time the old engine started failing, the mileage dropped, probably because of increased friction and reduced compression, but when I installed the rebuilt engine, the mileage did not improve again. I also noticed that when I let off the throttle on a flat road, the car starts to slow down fairly quickly, but that might just be me.
You have a D16Y8 manifold on a D17 engine. Did you install that before or after you started noticing a fuel economy drop?
