Old 07-21-2017, 01:52 PM   #8 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Thanks for continuing the thread. That's a lot of TEGs at $20-$25 each!
I think this description so far suggests significant complexity in using TEGs to replace an alternator entirely. A much simpler set up would contribute to reducing alternator need. It could be smaller and cheaper.
To tvago's good points, I assume we'd use cooling fins if we put a TEG unit into the under car airstream. Daox is talking about a lot of TEGs, and I think they would not easily fit around the manifold. Better to be lined-up along the straight middle sections of exhaust piping. Some sort of forced airflow seems possible under the car, along the piping, quite easily. Personally, I would sacrifice temp differential for system simplicity. Coolant circulation makes for complexity.
Any system would need some kind of controller, yes? And there would be a need for a way to prevent the TEGs from drawing power when the car is cool, maybe? There might be situations in which ambient air is warmer than exhaust piping, no?
Daox (07-21-2017)
