Originally Posted by Natalya
@IamIan:
This is such a wealth of information, thanks very much.
Very welcome , any time. .. Glad to help.
I was thinking I could use the custom stiff rear springs and possibly GAZ shocks that are now made for the car and then it would be okay to go a little above OEM weight.
Sounds good
Even just +10% of ~1,800 Lbs is another ~180 Lbs (~82kg) to work with.
Do your figures include removing the A/C or is this for a car that never had it? That's an additional ~20 kg.
A/C no .. and yes .. you could shave even more than that ~180kg off if you want.
From what I've been told/read .. the ~180kg number includes:
ICE + All support systems
Transmission 5 speed Transaxel
IMA + all it's pieces (motor, controllers, batteries, DC-DC , etc.)
You'll need a DC-DC of some type .. so you'll have to add some back in for that .. and unless you are doing a direct to shaft type , you'll probably have to bring back in the Transmission .. of course your Electric motor will have some weight too .. etc.
Originally Posted by Ecky
I'm thinking that 30kw continuous figure might be a little on the weak side if you live in a mountainous area. I'd go very slightly larger.
Of course can go as high as one wishes , they make lots of very power electric motors .. just a personal preference thing.
Just for comparison/perceptive:
At near ~OEM Weight .. 30kw continuous (with no wind) can hold constant speed up a ~30% (~17deg) slope at ~60MPH.
The OEM Insight ICE+IMA combined .. (any gear you like) .. doesn't get above 30kw output (even in rich with 100% max IMA Assist) , until you are over about ~2,500 RPMs .. and without IMA Assist the OEM ICE alone , even in rich burn and V-Tech doesn't get above ~30kw output until up near ~3,500 RPMs.
If you have a OBDII device you can data log with .. Like an OBDII-C&C + Laptop .. you can log your RPM usage window .. and of course each person's route / conditions / methods will vary .. but when I logged this for myself in my Insight for a year , I got .. I used a peak of over ~2k RPM only ~36.8% of the time (about ~25kw Max ICE+Max IMA Assist) .. and only used a peak over ~3k RPMs ~0.003% of the time (about ~36kw Max ICE and Max IMA Assist) .. soo , it would be ok for my usage pattern .. of course YMMV.
