If the Accord PHEV works for you, there's a good chance a plug-in Prius (PiP) will as well. PiP has the same interior/cargo volume as a normal Prius/Accord plug-in, and I've seen used PiPs for as little as $13k. The only difference compared to a normal Prius is a smaller gas tank and way less storage under the rear floorboard.
