Originally Posted by oldtamiyaphile
Darin ran a bunch of coast down tests are different pressures. The result was that there was a definite point of diminishing return at around 45psi, although that was with a light weight Metro. My Renault tyres are rated for 80PSI - I run them at ~65, my rule being to run as much pressure as my vertebrae will allow.
Mechanics always let my tyres down
My tires are only rated for 44 PSI maximum, so I do not want to go over 40 PSI because of the pressure increase as the tire heats up, and if I do, the pressure on a hot summer day of prolonged driving could easily increase above 44 PSI, and I do not want to cause a blowout or damage to the tires by exceeding the maximum safe pressure.
