Old 08-04-2017, 04:21 PM   #14 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Random recheck to see the market status of graphene batteries reveals this. And rough calculations suggest my ebike would get a little more energy capacity in slightly less space and with much less weight.
"LRP TC Stock Spec P5-HV Graphene 2S LiPo 60C Battery (7.6V/8000mAh). The HV-LiPo Graphene cells offer even more power than before and can be charged up to 8.7V without problem. The improved cell chemistry generates an extremely low internal resistance and therefore less heat buildup under load. HDS-7 cell chemistry guarantees maximum performance. Specially developed for stock racing classes with highest possible voltage output for maximum speed and acceleration.
P5-HV Technology: 5mm gold plated battery plugs and 7.6V (2S) technology for maximum power
HV-LiPo GRAPHENE cells: High power LiPo cells that can be charged up to 8.70V (2S)! Maximum Power!
100% compatible for 8.40V (2S): More Power than LRP 2016 batteries at 8.40V charging!
Improved Lifetime: Highly improved lifetme when charged to 8.40V (2S) only!
HDS-7 Chemistry: Improved chemistry for low internal resistance + less heat build-up under load = Maximum power until the end of your run
5mm Gold Works Team connectors included
3C Charge current
Charge with your standard LiPo charger for 8.4V or with LiHV charger for 8.7V
Complying with the rules of the following federations and race series: EFRA, IFMAR, ROAR, JMRCA, BRCA, DMC
120C/60C LiPo Power No memory effect, extremely long lifetime.
Durable, see-through, hardcase made of high-quality synthetic material
2mm gold coated balancing connector
LRP quality approved
Specifications:
Length: 139.0mm
Width: 47.0mm
Height: 25.1mm
Weight: 332g
Capacity: 8000mAh
Nominal voltage: 7.6V
C-rate: 120C/60C
Style: TC Stock Spec
Power connector: P5 5mm Gold
Balancing connector: 2mm Gold
Charge current: 3C
Application: 1:10 Onroad TC Stock + Modified
This product was added to our catalog on March 24, 2017."
The Following 2 Users Say Thank You to California98Civic For This Useful Post:
freebeard (08-04-2017), mikeyjd (11-28-2017)
