Nice! That should be much better than the bare trike. I say build it as a version 1.0 and test it out. Sometimes simpler and doable is better than the optimal design that never gets built.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
