Consider doing an upper grill block vs lower. Look at the corvette and other sports cars front layout where they intake cooling air almost always on the lower portion of the front. The bottom is messier for aero anyways, might as well keep the air path going over the car as smooth as possible.
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
