. They result in higher than normal temperatures that can cause matting erosion and burn away or melt converter coatings. If temperatures are high enough, the ceramic substrate itself will melt and clog
I read this as a timeline/ sequence of events. First it matting erosion and burn away or melt converter coatings. The point of failure you may be at no deformation of the honeycomb. Then if the problem persists or gets worce then you melt the honeycomb.
Have you checked the operating temp with a IR temp gun? ($20 horbor fraight) at the end of a long +mi run would be good or rushhour.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
