Old 09-18-2017, 10:55 AM   #298 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Darco results for my whale
Results .
DISCLAIMER:
As previously discussed my truck is larger than the tunnel is allowed to operate with for an accurate CDA number the tunnel walls interfere with the reading causing it to fluctuate to the high side. I'm still looking for the factory coefficient of drag number and that will tell me how much SKU was put into the tunnel buy the oversized
The variance between runs is accurate. It's the total value that's skewed
I input info working on the assumption that .45 is the stock it could be anywhere from .45 to .55 or higher, but shift the numbers that little bit and it will be accurate.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following 4 Users Say Thank You to gumby79 For This Useful Post:
aerohead (09-30-2017), BamZipPow (09-18-2017), freebeard (09-18-2017), Xist (09-18-2017)
