Completed mods:
(in no particular order)
- MPGuino fuel economy computer
See: http://ecomodder.com/forum/showthrea...vss-35550.html
- 50 PSI
- zero-toe alignment
- cleaned & regapped spark plugs (the gap was 0.010 wider than spec!)
- air conditioning delete (removed components)
- power steering delete (belt removed)
- ignition timing advance
- air dam, with...
- partial grille block
- half size radiator, and...
- one of two factory cooling fans deleted
- smooth wheel discs
- taller gearing (larger diameter rear wheels/tires)
- side mirrors delete/relocated inside
- LRR tires on the front, narrower than stock: 165/64R14 Dunlop Enasave
- wiper delete
- synthetic motor oil: 66% 5w30 + 33% 10w30
- weight reduction (goal: 100 lbs / 45 kg is attainable)
- MAF / open loop AFR adjustment
- synthetic lighter weight transmission oil (50% lightweight GM Syncromesh + synth 75w90)
- synthetic differential oil
- WAI - warm air intake
(More info & pics to come.)
Future mods:
- engine kill switch (been using the key)
- coolant/block heater
- reduce disc brake drag (springs are missing; service calipers)
- rear fender skirts
- fairing ahead of rear tires
- fairing behind rear wheels
- fairing behind front wheels
- belly pan
- decklid extension/spoiler?
- weight reduction: power steering pump delete
- lower it a bit?
Dream mods (but probably not)
- targa style aero bodywork aft of the seats
- mini boat tail!
