Old 09-20-2017, 06:02 AM   #10 (permalink)
oil pan 4
Those hubs have made multiple cross country trips.
The reason these hubs go out carrying so little weight is due to neglect. I would clean and repack the bearings for long distance trips, the one time I didn't turns out water had gotten into the hub and could have caused them to fail, but that's nothing to do with the bearings and tire size, I was in a hurry and cut corners. Trailer bearings need to be redone every 2 years, last time when they could have failed on me it had been about 3 years.
In a wet place like portland, you should probably clean and pack them yearly.
