Also, so that you don't have to waste money on a pump that just takes power from the alternator, take a 4 inch pipe that will hold the amount of water you need(or 6 inch if you need to!) and pressurise the system with compressed air. If you only need around 50-60psi then having a 5-10 gallon storage tank should be more then enough!!
