Old 10-01-2017, 03:52 AM   #79 (permalink)
cRiPpLe_rOoStEr
It's best to try to run lean with out water first.
Sure, but even if one is able to lean the mixture while not having knock issues the water injection could be used to keep NOx emissions under control, and eventually try more extremely with the lean-burn.
Originally Posted by ctmaybury@yahoo.com View Post
I would think that you can advance your ignition timing a bit with water as well as running lean.
Much like it's done with ethanol
