Old 10-14-2017, 11:48 AM   #104 (permalink)
oil pan 4
Yes EGR (on a diesel only) reduces power, fuel economy, warmup time and NOx, while it increases HC, CO and soot production.
I say if you don't live in a NOx and PM area then delete the emissions control stuff.
The worse part is the diesel particulate filter regen. Ford claims on their first generation of DPF equipped trucks that DPF regeneration can burn up to 17L of fuel.
I work with people who have newer dodge diesels and have deleted the emissions stuff, they said their fuel economy went from 15 to 20mpg up to 25 to 28mpg.
EGR on a gasoline engine is completely different, don't delete it. It normally gives you better fuel economy.
