Old 10-14-2017, 12:38 PM   #110 (permalink)
oil pan 4
Short trips are especially bad for DPF. Ford had DPFs get so bad the vehicle wouldn't run.
But it should take more than a single 5km commute to cause the DPF to need a regen.
If you use the diesel truck like a diesel truck, pulling a big heavy trailer over mountians and stuff the DPF fuel drain isn't as bad.
