Do you not understand that for example wind turbines use tons of steel and concrete. Concrete is very fossil fuel dependent. Iron smelting uses coal. The wind turbine blades use hundreds of gallons of epoxy or fiberglass resin which is a product of the petroleum chemical industry. Fiber glass also uses fossil fuels to be made. A typical hydraulic actuated 2Mw wind turbine uses up to 70 gallons of oil and hydraulic fluid. Then all these parts require the trucking industry to move them around.
Solar panels are just as bad if not worse.
And batteries take tons of liquid fuels to harvest and transport the raw materials. Dams take tons of liquid fuels and concrete to construct. Reactors take tons of liquid fuels and concrete to construct.
This is why I am trying to get across a sense of urgency to people that think we will so easily replace fossil fuels. And to the other half of people that don't see any problem at all. "Just put up some solar panels". "We have it made". It takes tons of energy to do all of this. It's getting late.
