Mpguino use with mechanical diesel
Hi all
As far as I can tell, the only issue with being able to generate a "fuel use" pulse is the lack of available flow meters at reasonable prices.
There are a a few marine sensors that have the required flow rates for my kubota d722 in my motorbike but they aren't that cheap.
If another arduino or a dedicated circuit can be used to deduct return flow pulses and then feed it real-time into the mpguino, this should work right?
Thanks all!
