What I'm asking is whether there is anything in the OEM part supply chain that uses the DAB converter instead of IGBTs.
Freebeard, those two things are apples and oranges. "Dual active bridge" is a topology for connecting multiple switching devices - think of it as a road map for putting the pieces together. "IGBT" stands for insulated gate bipolar transistor. It's a specific type of one of those pieces - the switching device.
So you could use IGBTs to create a DAB converter. Or you could use another type of device - say a MOSFET or even a bipolar junction transistor (BJT). At the company I used to work for, we did a pretty detailed paper design for a solid state transformer that used IGBTs. We built some of the subassemblies and tested them, but ran out of funding before we put it all together.
