I'm looking to disassemble and modify the light assembly. It only operated fer about 10 hours before it started flashing due to low battery power. I'll have to see if I can git a much longer run time by using a set of bigger batteries (D vs the current AAA). The batteries should be able to tuck into a compartment in the wheel pant. I should be able to easily to incorporate the light PCB on the end of the wheel pant.
