Old 11-26-2017, 05:13 PM   #94 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
an artfully shaped (per aerohead) shark-fin to each outer end and you can create an air curtain that will throw a flat jet of fast air over the front wheel opening. It would be a convergent duct aimed somewhere between the outer edge of the tread and the sidewall.
Air curtain would be fun to make. I'm still adding the crude mods to the car though. Walk before run.
We know ducted air curtains work. They're showing up on more and more conventional vehicles. The trouble with DIYing stuff like that is I bet the improvement is relatively small, which makes it hard (without a wind tunnel) to know if you made things slightly better, worse ... or no change.
