Old 11-26-2017, 07:10 PM   #6 (permalink)
Tinchariot
Tinchariot's Avatar
The next mods will be new fuel injectors, port the upper intake manifold when I have it off. If the fuel pressure dose not come up to factory spec's , it will get a new fuel pump. Wrap the exhaust down pipes with heat wrap to lower under hood temps. Plan upon blocking the open grill area. Perhaps move the air temp sensor out of the air box closer to the t-body. Adding a Dynomax turbo muffler with a single 2.5 exhaust pipe. Change to all fluids to full synthetic. First thing I did was remove the luggage rack. Adding some sort of spoiler and maybe a belly pan? It sure would be nice to get the milage Ford says it should get from the factory. I need something to haul my dogs around in and this thing was free from my aunt who just passed away. My old 190DT Benz fuel pump died after 75 K of straight WVO. RIP for now!!
