Old 12-14-2017, 12:13 PM   #5 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
I am for "less is more" when I look at your list. If you are not leaking oil, then leave the valve cover and oilpan gaskets alone, for example. But definitely do the timing belt. It is supposed to be changed every 90,000 miles on our civics. Assume it was not and change it as a precaution because if the old one breaks your "interference" engine will destroy itself in an instant.
Hoping that helps...
james
mazdamx640 (12-14-2017)
