Old 12-20-2017, 10:25 AM   #92 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
This build looks nice and tidy so far. I will be watching with interest.
Originally Posted by ctmaybury@yahoo.com View Post
Interesting spot for your battery. Do you have 2 batteries? I have a grid heater on the Cummins, and it is a power hog. I think you said you have glow plugs. They have to be just as big of a power hog. That combined with the high compression (extra work for the starter motor), you might need a second battery.
The gel or AGM batteries seem to have more Cold Cranking Amps in a smaller package than the old lead acid batteries. That said, I live in a very cold climate and would want plenty of battery capacity if I needed to park outside overnight. I kept a lithium ion boost pack in my Grand Cherokee CRD before I sold it. It helped if the battery was a little low.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
aardvarcus (12-20-2017)
