Old 12-20-2017, 11:35 PM   #198 (permalink)
cRiPpLe_rOoStEr
IIRC the twin-turbo setup is used only in some Diesel versions, with a pneumatic starter (similar to the ones fitted to modern aircraft engines) for the low-pressure turbo in order to overcome turbo-lag, while the gasoline-powered ones have either a single turbo or a twincharger setup.
Originally Posted by Fingie View Post
It's kinda funny, yes. Considering both diesel and gasoline engines are based on the same 2.0 Block
That's the point.
