Okay, Red Green, let me at least try to do it right first, all right?
Another celebrity gave me his opinion:
Cutting and splicing the wires wont work, that will just cause a fuse to blow. Check to see if the connection to the pigtail is bad.
Shouty's way may work fine, but I know that when people on here talk about adding fan indicator lights and other things, they always talk about installing a fuse.
So, set the gizmo to ṽ, and use the two plugs on the right side?
