Old 12-28-2017, 10:57 AM   #988 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 50.97 mpg (US)
There might be some reasonably cost-effective way to heat it electrically. Why not try some heater pad like those ones that some people are using to heat the oil sump?
Wouldn't the amp draw on the alternator more than offset any minor gains in aero?
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following 2 Users Say Thank You to COcyclist For This Useful Post:
aerohead (12-30-2017), BamZipPow (12-29-2017)
