Old 12-31-2017, 11:04 PM   #51 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Covered in link in post 45 above. Sometimes it helps to follow the White Rabbit down the link hole, see you on the other side Alice.
Cooling covered. Positive air flow as a result 100's of cfmof intake charge flow.
Mount the RC or better muiltu pole 3phase ac aka BLDC motor( same thing as a permanent magnet alternator) into a viscosity stack centerable on stator vains that improve the turbocharger proformance.
Rpm limit 400,000 rpm @700w 50k 7500w. See link.above For link.
Oil pan
I called Turbonetics about the RPM question
called Turbonetics teck department... and yes we can regulate shaft speed to a specific max rpm is an achievable goal. Just open the waste gate.. teck said 20,000 was a very reasonable goal.
Atmospheric temperature is all the genhead would see and a fraction of that as the suction of the impeller would have a cooling effect. Run off the cold side. From linked post.
You could use the voltage signal from the motor as an input to Raspberry Pi which would tell a Servo to open and close the vgt veins on a he351 v e based on RPM. Standard Automotive plus minus 3 bar map sensor and now you've also got a boost Factor the Raspberry Pi can control your he351 or any other vgt Turbo. Add a drive pressure s sensory as well so you can actually adjust your power output so asto not overdo it on the exhaust Drive pressure causing an EGR effect by not being able to expel all of this spent gases. Then again excessive drive pressure maybe the key to running diesel on lean burn.
It would take something like and E motorcycle controller to be able to handle 10 horsepower electric motor regen and spool up assisting. And a sizable buck-boost for times when the wheels are not spinning fast enough. What I learned at the NDHRA National Diesel Hot Rod Association drag race) in Billings Montana; the ideal Drive pressure is1:1 meaning one pound of exhaust pressure is 1 lb of intake pressure so you can load the turbo to this ratio and not hurt the motor.
Dreem Big Chisel Down To Reality
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
