Old 01-05-2018, 05:58 PM   #36 (permalink)
cRiPpLe_rOoStEr
Originally Posted by order99 View Post
Not noticed any appreciable change in FE from my 2013 ZenN 50 cc-honestly i'm not sure if it's because I keep Boat Gas (93 Octane 0% Ethanol) in the tank or because I only have a 0.75 quart oil resevoir (fast heating as a result). Then again, the 1.2 gallon tank might not be large enough to show the tablespoon or so difference. :P
Might be due to the absence of ethanol, since it doesn't absorb moisture with the same intensity and thus is likely to vaporize easier even when it's extremely cold.
