Old 01-08-2018, 08:33 PM   #125 (permalink)
cRiPpLe_rOoStEr
probably the easiest and cheapest is a belt-mounted hybrid motor/generator - it can go in place of the alternator, bolted to the engine, with a beefier belt
I'm aware of its use only in vehicles fitted with automatic transmission, but maybe it wouldn't be so bad in a manual. I'd just be concerned about its effects on the clutch life.
motors attached in-line with the driveshaft (requires custom driveshaft, but has advantages)
Reminds me of that setup provided by ZF and currently fitted to Volvo hybrid buses, with a clutch and a motor in a single unit. Since the buses fitted with it rely on an automated-manual transmission, maybe a similar configuration could be OK with a strictly manual transmission.
