Old 01-09-2018, 06:29 PM   #154 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
Originally Posted by Phoenix'97 View Post
What I am trying to say is that I am burning a set amount of fuel yielding enough power such that the taxation from those two rear hub generators does not effect fuel consumption considerably enough to make much of a difference. In so doing, the goal behind AWD electronic assist is to help keep the V8 motor at very low RPM where it would normally be "lugging" but with the added power from the front electric motors, it can now operate with this notion of "efficiency" which helps to reduce overall gasoline or bio-fuel consumption.
So goes my logic.
I see two points here:
Q) Is the loss of this system going to actually be noticeable in my fuel economy? Because I'd really like to have AWD
A) Yes, I think it will. The amount of loss in fuel economy will be directly proportional to the amount of power that you add to the front wheels. If you only wanted 1HP up front, it would be miniscule. You could add 200HP up front, but you probably couldn't go 20 miles on a tank of gas trying to turn those generators. And, the more power you try to send up front, the less total power your car will have - because the system operates at a loss!
Q) Can I prevent my motor from lugging this way?
A) Lugging happens when your load is too high. This will add load to the engine - you're burning more fuel, after all, and your gas mileage is going down by doing this. The generators don't run for free, they're leaning heavily on the gas engine! If anything, it will lug worse.
You're asking to put extra load on the gas engine to give it to front motors, but you'll always load the gas engine more than you get from the front motors.
Phoenix'97 (01-09-2018)
