Old 02-05-2018, 12:16 AM   #12 (permalink)
cRiPpLe_rOoStEr
Originally Posted by Daschicken View Post
Oh yeah, and to add to the discussion, I can only assume that the heat coming off of the transmission tunnel in the miata is from the exhaust pipe, not the transmission, so even fwd cars COULD have that heat problem.
Yes, that excessive heat is most likely to irradiate from the exhaust than from the driveshaft.
However, I have never felt heat coming from that tunnel in any cars but the miata and S2000. OP, can you feel heat coming from the tunnel?
It might also relate to the space constraints in the tunnel in order to fit both the driveshaft and the exhaust. But anyway, in most FWD cars I used to see some aluminium-faced heat shields surrounding the exhaust pipe when it goes through the tunnel.
