Old 02-06-2018, 04:15 AM   #2 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Bad switch, bad relay, bad ground...take your pick.
Relay tends to be the easier and cheaper to replace. Easier if you can get the issue to occur while you're parked so you can do some testing. Fiddle with the multifunction switch to see if you can cause the lights to cut out, and or tap the relay (with an assistant to watch the lights) to check for the same.
