Old 02-09-2018, 01:45 PM   #70 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by Stubby79 View Post
I'm cheap...I'd go source one out on ebay. Just make sure it's designed/rated for the right number of cells and chemistry(though your BMS will probably prevent over-charging...you still need enough voltage). You can always change the plug on it to match your battery's charge port.
There's probably a 5a one out there. I bought a 5a 72v one a while back.
Quick search example:
https://www.ebay.com/itm/371918053640
Wow, that is cheap! And it is virtually my exact charger, but higher amperage. And mine has the plug with a male stem inside a round barrel. It only has +/- and no ground (I think), unlike this three prong which is grounded. What would I do with the ground wire? Maybe an adapter? Cut it and wrap it? I suppose I could dismantle the battery box and replace the female plug instead. Hmmmm.... I wish there was still a plug and play but I have been looking and suddenly they all seem to be three prong.
