Old 02-10-2018, 09:21 AM   #8 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
fuel economy impact?
Correct: only goop came out. The check valve stopper was intact as confirmed by cleaning the part (as you do).
Here's a question: how would a malfunctioning PCV valve hurt fuel economy?
I suppose if it's stuck open, it'd be continuously feeding some amount of oxygen-depleted blow-by gasses to the intake. That in itself should be slightly good for fuel ecnomy (like EGR) assuming it's a modern car with a properly functioning oxygen sensor: diluted intake = reduced power potential of the engine = wider throttle opening & reducing pumping losses.
But what if it's stuck closed? It'd increase crankcase pressure and possibly cause oil leaks (so I read).
