Old 02-12-2018, 05:40 AM   #6 (permalink)
Fingie
Volvo-driving MachYeen
Fingie's Avatar
Neo Volvo - '98 Volvo S70 10V
90 day: 24.98 mpg (US)
YKYDJJW when you instruct your friend how to get the Volvo in reverse without the gearbox crunching
YKYDJJW when you have to gently knock on the headlight relay sometimes when headlights suddenly turn off
YKYDJJW when you must often fill coolant because the hose leaks when cold
YKYDJJW the engine leaks oil and you just shrug because the engine will be swapped this year and well, the underbody won't at least rust
YKYDJJW you cross your fingers at the inspection
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
The Following User Says Thank You to Fingie For This Useful Post:
MetroMPG (02-12-2018)
