Old 02-14-2018, 04:03 PM   #987 (permalink)
RedDevil
90 day: 56.53 mpg (US)
According to the National Academy of Sciences sea level is not only rising, but rising progressively.
Climate-change (PNAS, 12 Feb 2018)
Satellite altimetry has shown that global mean sea level has been rising at a rate of ∼3 ± 0.4 mm/y since 1993. Using the altimeter record coupled with careful consideration of interannual and decadal variability as well as potential instrument errors, we show that this rate is accelerating at 0.084 ± 0.025 mm/y2, which agrees well with climate model projections. If sea level continues to change at this rate and acceleration, sea-level rise by 2100 (∼65 cm) will be more than double the amount if the rate was constant at 3 mm/y.
