Old 02-23-2018, 12:53 AM   #8 (permalink)
puddleglum
puddleglum's Avatar
Rondo - '07 Kia Rondo EX
Last 3: 20.47 mpg (US)
Tinkertoy2 - '00 Toyota Echo base
Last 3: 46.03 mpg (US)
Originally Posted by California98Civic View Post
Do you have the factory service manual?
One nagging question: wouldn't the resistor fail throw a CEL?
I do have an online version of the service manual, it's been helpful since the Haynes manual for the Echo is out of print.
If by resistor you meant the relay, no it wouldn't. It's a normally closed relay mounted in the power supply wire to the injectors. The computer doesn't monitor that wire from what I can tell. That's why I chose that location. If it is the cause, the only way I can see it could cause the problem would be that the contacts didn't close properly causing too much voltage drop to run properly, but enough to allow it to start. That's a bit of a long shot, but it's running just fine now so until it fails again, there's not much more I can do other than prepare for further testing.
Almost all my driving is done 1-5 miles at a time.
Best short trip: 2.4 l/100 km, 3.9 km
