Old 02-23-2018, 04:38 PM   #74 (permalink)
freebeard
This would be my most buildable concept: Supereliptic Morelli body with single-speed Toyota HSD axle.
http://ecomodder.com/forum/showthrea...tml#post562058
The Lexus axle is 18" across so you could attach wheels directly without axles and get a narrow rear track. If the front wheels are held within the maximum width of the teardrop body, there will still be turbulence flowing down the sides. I think it might be better to move the front wheels forward and out for a stance like this Beetle:
The superellipse can be as close to square as is needed to accommodate the solar cells and flat sheet materials. And as curved as possible for crosswind performance.
What the headline giveth, the last paragraph taketh away. -- Scott Ott
