Old 02-27-2018, 11:50 PM   #77 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Originally Posted by California98Civic View Post
I used a multimeter and probed, but I am sure I did not have both ends hooked up. In the past, when plugged in, the connector woul spark at the battery. I assumed that meant there was power from the charger, but of course it could be the battery's own power. I should take it apart again and plug both ends in and retest? I could not see anythin that seemed burnts or melted. Maybe the underside of the board?
Could be the capacitors charging up that make it spark...does it spark if plugged in to the wall first?
Could also signify something more significant and potentially hazardous that could damage the BMS. Might be a good idea to check for continuity/resistance between the + and - output end, in case it's shorted between them somewhere.
The Following User Says Thank You to Stubby79 For This Useful Post:
California98Civic (03-02-2018)
