Tail gun seating is this, at least what I found :
Seats with back to back (back od front driver oposite to the back of passager behind, have a problem I just figured now. It need to be 90 degree, fixed, otherwise the other person will have reverse (supplementary angle) angle.
Diamond pattern ???
Another problem from Aptera, in regard the large wheels (too thick) is the fact there was a large space from the wheels streamlined cover to the ground, since usual city streets have gaps that would broke it.
I imagine a wheels streamlined covers that would have a adjust of heigth, like one portion of the cover would enter in itself, to make the wheels more noticeable and have less danger of a gap on street broke the covers. For roads in fine shape it could be closer to the ground.
I also imagined a approach to allow more angle/lateral moviment for front wheels without need a very width value to the wheel covers, but it's difficult to imagine a way to use this idea together with the idea adjustable heigth.
Anyway, to allow more angled moviment/angle of front wheel, like for parking between two cars, I imagined two small ports in each side, that ould open as the wheel pull it when we turn the steering wheel a lot. In normal drive it would not be used a lot, since the wheel angle would not change enough.
Rear seat passengers feet normally go under the front passenger's H-point anyway. That close coupled tandem seating doesn't gain much. Tail-gunner seating will never be popular with anyone over 6 years old. A diamond pattern instead of side-by side conserves width.
Increasing width with length doesn't improve the fineness ratio.
Software: Some programs have a learning curve like a stroll up the hill, others are like running smack into a wall. I have struggled with a number of programs, Blender and others I try to forget.
I suggest for your consideration Wings 3D.
I can wrap my head around it's process, but still need to study to figure out how to complete arbitrary tasks. The work flow goes select — right-click to select from contextual menu of options — middle-clicking and fiddling around — left click to accept/escape to revert. Rinse and repeat. Navigation and camera movement can be changed to mimic other popular programs and you can work with a single, double or three-button mouse.
The current version requires a later OS than I have, and the old version lost it's status bar, so I'm not doing much now, just trying to prep an 'new' computer for the current threat environment online. It's a Core2 Duo Intel processor so it should be immune to Spectre/Meltdown. I still have concerns about BadUSB, and I want a hardware firewall ahead of the software firewall in the OS.
