Old 03-15-2018, 08:38 AM   #2 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
I was under the impression torque is improved on the low end by having appropriately small valves - that's the point of Honda's VTEC, isn't it? You have small / fewer valves open at the low end because it still flows adequately, and you get better combustion due to better mixing. More/larger valves open as the engine revs up to let in the extra air needed.
