Old 03-16-2018, 02:24 PM   #12 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Actually, I want to correct my last post a little. The Fit auto's freeway RPMs, in top gear are 23% LOWER than a Fit manual would be. Your RPMs will also be significantly lower than the Fit manual in 4th gear (I did not calculate how much but maybe near 20% lower). Basically, the final drive gear is significantly shorter on the auto, but most of the auto's higher gears seem so much taller than on the manual that they way over-compensate. Highway cruising RPMs in your Fit should be significantly LOWER than a 2001-2005 Civic HX manual (like maybe 8% without accounting for wheel/tire size).
You could certainly work harder using a Fit manual trans and get better FE (check out the "PaleFit" on this site), but your auto is serving you pretty well.
Get the taller 195/65-16 wheel/tire combo I mentioned and your actual cruising RPMs on the freeway might match the legendary Civic VX fuel sipper.
I think I got it right this time.
Fit_is_slo (03-16-2018)
