Old 03-19-2018, 09:00 AM   #41 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
Originally Posted by CapriRacer View Post
Ah ..... not exactly. All standard load passenger car tires (the most common type) have a rated pressure of 35 psi, except for those tires who use the metric system, then it's 2.5 bar (250 kPa, ~36 psi).
Please note: This is different than the max usage pressure which is sometimes written on the sidewall (and the other times what is written there is the rated pressure.)
This is different than bicycle tires because bicycle tires assume a single rider and a relatively narrow range of weight, while a car might have many passengers and a wide range of weight.
The tires aren't rated at 35 PSI, to my knowledge. The placard in the door says ~35 (give or take) because that's generally the correct pressure for the stock tire size that comes with the car. If you upsize or downsize, this pressure is no longer correct.
