Old 03-25-2018, 09:11 AM   #32 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Originally Posted by mpg_numbers_guy View Post
Good point, but you can't really store much cargo in an Insight either.
You can't move a full size 6ft bookcase in a Civic, that I'm aware of. I wouldn't ever want to own a non-hatch.
Here's 8 tires and 8 rims (separate from the tires) stuffed in the back:
But I digress.
If a CVT normally maintains the lowest RPMs possible, how are they less efficient than manuals? I always thought manuals were more efficient than automatics just because one could "force" them to upshift sooner.
Friction losses. In a CVT, there's a belt which rides between two cones, and the cones slide together or apart to change the gear ratio. The belt has to ride in oil because it would get very hot. Early Honda CVTs could be expected to last ~150-200k miles before wearing out.
However, CVTs can have very wide effective gearing ranges and sometimes that more than makes up for their frictional losses.
Traditional automatics use a torque converter, which transfers power between surfaces moving at different rates, much like the clutch in a manual, except they're "slipping" much more frequently. This eats at least 10% of your engine's power.
mpg_numbers_guy (04-22-2018)
