Old 03-28-2018, 02:24 PM   #71 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
You might want to go higher than 175. I have Tein H-tech springs, and the rears are 170 lb/in, and they're too soft for my liking still. You don't want to go higher than the dampers can handle, but RS-R Superdown springs for the Prius run 185 lb/in rear, and are meant for the stock dampers. So you can probably go higher.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
